что-то моя учетная запись "Tolka" перестала работать....
Wheelman in Brief
The wheelman we are offering is the latest model in 2008.
We are the original manufacturer of wheelman. With design inspired by the surf board
concepts. Get the same rush anywhere anytime. This is one of the most innovative products.
The Wheelman is a revolutionary new breed of gas scooter. You stand in it just like a
snowboard, and cruise at speeds of 45+ MPH! Comes with a huge 49cc high performance
engine!
Sports a high output 49cc motor, so you won't be lacking in power and knobby wheels for
tough terrain. Ride it off road in the trails, in the snow or on the beach (wet sand only)!
High quality components are used throughout, To back up the quality there is a 180 day
warranty. At speed, use your body lean to steer, just like a skateboard. The low center of
gravity assures complete control! You can do up to 45 mph on or off-road OR crawl at half
walking pace!
Confident, smooth ride includes a hand held accelerator/brake AND the patented HUBLESS,
SPOKELESS wheels!
Ships fully assembled & ready to go!
Powerful 49cc Wheelman with 45 Degrees Climbing Capacity
Model Number: WZGS4304
Key Specifications:
1. User age: > 16
2. Wheel number: 2
3. Piston Displacement: 49cc
4. Horse Power: 2.0hp
5. Fuel Tank Volume: 0.90liters
6. Fuel Type: Unleaded Petrol/Oil Mix (Ratio 25:1)
7. Motor: 2-stroke, 1-Cylinder, Air-Cooled
8. Starter System: Manual /Electric starter(optional)
9. Ignition Method: CDI
10. Max speed: 45km/h, 21.7miles/h
11. Distance on full tank: 40km/25miles
12. Brake: Disc brake
13. Power transmission: Single Speed-Centrifugal Clutch
14. Load Capacity: 120kgs/264lbs
15. Climbing capacity: 45 degrees on 61kgs loading
16. Wheels: 14 inches Knobby Tires
Package:
17. Carton size: 115 x 33 x 46cm/1pc
18. Net weight: 27kgs/59.4lbs
19. Gross weight: 29kgs/63.8lbs
20. Container: 150pcs/20’; 320pcs/40’
21. Color available: red, yellow, blue, silver, black and white
